Thread: Pump, Blower, Valve overhaul
    Redeyejedi's Avatar
    Mar 2017
    cali
    4
    Hi,
    I recently noticed a decline in pressure/ vacuum performance.
    I cleaned filter grids that were replaced late last year, several that had actually been broken a couple at the port.
    Had plenty of pressure with bottom drain open, now minimal closing it off.
    Checked cleaner, 'the pool cleaner' inside for obstructions, all clear.
    Pump basket clear.
    It could be a failing pump(have a replacement)? A faulty check valve? Blockage?
    I have to replace two diverter valves, a blower, and the pool motor, so in the near future i will different location to the plumbing line. Upgrading to the NeverLube valves and adding actuators. I also have to re-do much of the electrical and bring switches to a more convenient location.
    Thanks for any advice,
    Aaron
    40k gal, 15'*35'*7.5' rectangle with attached jacuzzi spa
    old inttilflo wetend with centurion pumpback, purex heater and filter
    mas985's Avatar
    Pleasanton, CA
    11,984
    Re: Pump, Blower, Valve overhaul
    What is the filter pressure now vs when you last cleaned the filter?
    Mark
    Redeyejedi's Avatar
    Mar 2017
    cali
    4
    Quote Originally Posted by mas985 View Post
    it looks like it was a faulty check valve and the flapper was getting jammed. the from the clorinator
    mess
    blower,
