Thread: Hello from LeClaire, IA
    Jun 2016
    Le Claire, IA
    2
    Hi everyone! I've been a pool owner going on three years now. This summer will be the second time I've opened the pool since we've moved into the house. We have a 24' across above ground pool with sand filter. Going a different route this year and steering away from the 6 in 1 packets. Going to try and conduct my own testing too if I can get my hands on a Taylor K-2006 kit.
    Any advice is greatly appreciated!
    ~Josh
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hello from LeClaire, IA
    Welcome aboard!
    Spend some time in Pool School if you haven't already, especially on the ABCs!
    If you don't already have a test kit, the TF-100 is a better overall value than the K-2006. It has all the same tests, but with more reagents so you can get more tests from the kit. It's almost always cheaper as well.
    TFTestkits.net
    The SpeedStir is a very nice addition to the kit. Makes mixing easier and testing more accurate. Not required, but I'd never test without mine!
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
