Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Please help a n00b identify some holes
    Jun 2016
    Palm Harbor, Florida
    62
    Hello all,
    My pool was working ok last summer, but I have a lot to do with it before swimming season. Can someone please tell me what the following holes are for? [gosh, it sounds hilarious asking that question]
    The first port looks like it is a vacuum line of some sort, but I never could get it to suck (or blow), no matter how I positioned my pump valves. Is it indeed a vacuum line? It is around the height that a return jet is.
    Attachment 58308
    The next hole is located on the pool deck right adjacent to the deep end. It has a twist off cap. When I twisted the cap off and looked inside, all I see is a pipe headed straight down.
    Attachment 58309
    Attachment 58310
    I am VERY curious as to what this pipe leads to. I am getting ready to drain my pool, and a sewer is not nearby. I also do not want to drain into my yard, because the water is full of fungus and disgusting. I've read that I can drain it to the "main drain" of my house, but I don't know where it is.
    ANY advice on what these holes could be would be GREATLY appreciated! Thanks in advance!!!
    Here is another pic of the last hole, to give you all more perspective on where it's located. The hole is outlined by a red square:
    Attachment 58311
    12,150 gallons; in-ground; cartridge filter; 1986; K-2006 kit
    Feb 2016
    Baytown, Texas
    40
    Re: Please help a n00b identify some holes
    The hole on the deck is for an umbrella.
    Xavier in Baytown, Texas
    Pool Built: 06May2016. 16ftx34ft, Area: 485 ft2, Depth: 4ft-6ft, Pentair IntelliFlo Variable Speed Pump, Pentair FNS Plus D.E. Filter 48 sq. ft., Easy Touch 8 with wireless remote, IntelliBrite Pool Color LED, 640 Sq Ft of deck, 3 ton waterfall, Guesstimation: 17,000 gallons, Test Kit: Taylor K-2006C.
    Seems like an odd place for an umbrella.
    How deep does the hole go?
    It might be a well point to drain ground water in case you need to drain the pool.
    Is the pool fiberglass or concrete?
    Support the site
    Sep 2016
    Dallas, Texas
    188
    Quote Originally Posted by misplacetexan View Post
    Matt- IG gunite pool and spa built Summer 2016: 32' x 20' overall with two 4' x 8' tanning ledges. 6'x6' attached spa with spillover. Depth 3' to 5' to 4'. 16.4K gal. Lueders Limestone retaining wall and coping. Equip: Pentair SVRS vari. speed pump. Pentair 60 sq. ft. DE filter. Pentair Kreepy Crawly Plat. cleaner. Pentair MasterTemp 400,000 BTU NG heater. 1.5 HP spa air blower. Nature2 Sanitizer. Taylor K-206C. My 2016 Build
    Jun 2016
    62
    Wow, I am genuinely intrigued by the answers. I don't know how far down the hole goes. I will stick a broomstick or tape measure down there in the morning and try to find out. If it were a pipe to drain ground water under the pool, that would be cool. So - if it only goes down a foot or so, it must be an umbrella holder, eh? My pool is a concrete pool built in 1986. I bought this house last April.
    I ordered a pump to drain the pool. I still don't know where I will drain to. When i figure that out, I will drain to knee-depth, then try to find and remove the hydrostatic valve, which should be adjacent to the main drain. I hope knee-deep water is enough to keep the pool from popping up. It has been at niche-level for many months (had to remove the light cord, which was epoxied in place, and then pool started leaking, but stopped at the niche level.
    Sep 2016
    Dallas, Texas
    188
    Quote Originally Posted by kri5tian View Post
    A question that I forgot to ask was, "Is this the only one around the pool perimeter?" If so, I would agree that it seems like an odd place to put the only umbrella holder...
    Could be an umbrella sleeve. If it's not deep, then that seem most likely.
    Support the site
    Jan 2012
    'burbs of Augusta, Georgia
    8,566
    My well point under my fiberglass pool is wide enough to drop a small sump pump down into. This does NOT look bigger than an umbrella pole.
    Just my two cents
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    I agree that it's most likely an umbrella sleeve.
    Dewatering systems for pools can be done several ways. For fiberglass pools, it's common to put a pipe about 8" to 10" in diameter as a dry sump well. This is not a well point. The well tube is large enough to drop in a sump pump to push water up and out.
    What is a pool sump and why MUST I have one? - YouTube
    A well point is a different way to dewater ground water. It works like a typical pipe for a well. It's basically a 1.5" pipe going under the pool and it has a well point on the end.
    To pump out water, you connect a pump to the pipe and pull the water out of the ground.
    The pipe can be somewhere around the pool or by the equipment.
    Support the site
    Jan 2012
    8,566
    By Jove James....that's twice tonight I've learned the *proper* names for things from you! Thank you!
    <Yip scratches out "clear" and "well point" and writes "colorless" and "sump well" on a piece of scratch paper.....that she'll probably lose tomorow, but hey!.....>
    Yip
    Jun 2016
    62
    Ok guys, I stuck the end of my brush pole in the hole, and it would only go down 3 ft. So, I peered into the hole and it looked like it might curve at the bottom. I got out my plumber's snake and was able to fish it down the hole to 14 feet 2 inches before it bottomed out!!! Also, when I shook the snake around, it sounded like it was wet down there. When I pulled the snake back out, sure enough, the end was wet. This is the ONLY hole around the pool.
    So - PLEASE get back with me guys! If this is a well point like James says, what do I do? I ordered the "Superior Pump 91330 1/3 HP Thermoplastic Submersible Utility Pump" from a website and it is arriving today. I want to empty the pool so I can begin my cleaning out process. Should I somehow try to attach the pump to this pipe and pump out the water below? I was planning on emptying the pool to knee-deep level (right now, the water is at niche-level), and then removing the hydrostatic valve by the main drain. I guess it's better for me to first try to pump out the water from this pipe?
    One more big question - why can't I pump the nasty pool water into one of my toilets or my outdoor sink? Sure, I would have to constantly monitor for clogs, but it's doable, right? In the meantime, I'll search for this mythical "main drain" that is supposed to exist around my house.
    Also, I see one of the holes that I asked about (the one I thought was a vacuum line) did not post in my original thread. Here it is.
    Attachment 58323
    can you guys tell me what it's used for? It has a spring loaded cap, and my finger is holding it to the side.
    Jan 2012
    8,566
    You have an inground pool, but is it Fiberglass or plaster?
    Looks like it's a well point. Typically, you connect a pump to pump out the ground water.
    The other hole is probably a vacuum port.
    Support the site
    Jun 2016
    62
    YippeeSkippy, my pool is plaster.
    JamesW - thanks for the reply. [I don't know why I'm not getting e-mail notifications when people reply to my threads! I have that box selected in my settings. Oh well...]
    So I'll proceed with my plan to first try to pump the water out of the well point...and then get it knee-deep in the actual pool before trying to remove the hydrostatic valve. Thanks to all!!!
    Jan 2012
    8,566
    did you remember to hit "save settings" at the very bottom when you set it up?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,728
    It depends on how much water the pump moves. The volume of water going into a toilet or sink would probably overwhelm the capacity of the toilet bowl or sink and overflow.
    Look for a cleanout near where the plumbing would enter the house, like close to where the kitchen sink or toilets are located. Most cleanouts are outside the house, but some houses have them in the basement. It will be a pipe kind of off by itself with a cap that screws onto it.
    Love TFP? Become a
    TFP Supporter!
    Captain 776's Avatar
    May 2016
    Thailand
    163
    Go to Home Depot, get as much 2" hose as you need to reach the street, you must have storm drains in the street and you can use the same hose when you need to backwash.
    you COULD......dump it in your main drain for the house...........there should he a T-Wye where your sewer line exits the house, on one side of that T Wye..........there will be a 4" plug.........for cleaning out the sewer, you can remove the plug and stick the hose in there, but I highly recommend draining to street if u can
    8M x 4M X 2M no slope IG CONCRETE w/ceramic glass tile
    17,000 Gal EMAUX SWG JAZZI FILTER W/1-3 mm glass media, Jazzi Multi-port valve with
    T-750 filter w/ glass media
    1 main drain sump -3 returns - 1 skimmer
    Kokido digital salinity tester, Kokida drops for CL Hanna digital PH meter, Taylor K-2006
    May 2016
    Thailand
    163
    Do you know how to open the vacuum valve so you will have suction.
    you should have a valve for skimmer, a valve for main drain in bottom of pool and the other one is the one u open to get suction on the vacuum line.
    Jun 2016
    62
    Well, my sump pump arrived and it just dawned upon me that it won't work to pump the water from the well point (duh!). I need to research another method to do that. Also, there is obviously quite a few feet of air in that pipe before it hits water, so that could cause priming problems, depending on what pump/method I use. I almost want to roll the dice and just empty the pool to knee-height, then remove the hydrostatic valve, but nobody on here has given me their blessing to do that.
  20. Back To Top    #20
    A self priming pump should be able to get prime on the well point.
    The well point can give you a good idea about how far down the ground water is.
    How far down did you hit water when you checked the depth of the well point?
    Draining is risky unless you're sure that the ground water is not high enough to float the pool.
    Support the site
