Thread: New and need advice
    Mar 2017
    MN
    2
    New and need advice
    I found this wonderful forum site last year while researching to put up a 16' above ground intex pool. I ended up doing it all myself and learned a lot. I used the pink foam 1 inch boards taped with gorilla tape as my under base and it held up and worked great. In fact it would still after having had the elements through fall and winter on it be just fine except i didnt think of one thing. We had a bad wind storm blow through and it took my exspensive board and busted many areas. Unfortunately i could only save 2 boards and will have to buy more to replace. Because of the exspense im wondering if i would be able to do 1/2 or 3/4 inchs and just replace with all new board. I have under the board just tamped down black dirt and blocks leveled with the dirt to set the legs of the pool on after i put my foam board. It may not make a difference in the end because if the price to do all new boards of 1/2 to 3/4 vs replacing 5 1inch boards. May be the same.
    Yet ill pay it all over again for the 1in if its going to make a difference as far as durability.
    Does anyone know how well tape comes off boards?
    So if you have used the pink board as your base and it was 1/2 or 2/3 please let me know your exsperience. One things for sure this up and coming winter will include bricks to hold them boards down.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: New and need advice
    I never used that stuff, but I think if you warm up the tape with a hair dryer as you go, it might help a lot in peeling it off with minimum damage. Sorry, that's all I can add.
    Essential Links:
