Thread: Clogged Only Main Drain Pipe...HELP
    Mar 2017
    Arlington Texas
    2
    Question Clogged Only Main Drain Pipe...HELP
    While draining my pool, some debris has clogged my main drain pipe. So, I am needing to remove the Only Main Drain Cover (SMod 07017-0751) took out my screw driver...to discover the 2 tiny holes I thought were the screw holes WEREN'T. Not sure how to remove cover...?
    Thanks
    Jan 2012
    'burbs of Augusta, Georgia
    8,557
    Re: Clogged Only Main Drain Pipe...HELP
    Do you think the debris came in from the main drain or the skimmer?
    Can you run a hose or snake from the pump end *backwards* to force the debris back the way it got in?
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    GoGrabTheNet's Avatar
    Dec 2015
    Phoenix, AZ
    65
    Are the screws the security bit type? They look like a Torx pattern with a pin in the middle. That's how my covers are. You'll need a security bit to remove it. Cheap sets are available at Harbor Freight...and they are cheap in price and quality, i.e. the little hole to accept the pin may not be in center.
    13k Gal. PebbleTec IG pool : Pentair IntelliFlo VS pump : Hayward 8-cartridge filter system : A&A in-floor cleaners : Jandy 115k BTU heat-pump : A&A auto-filler : Stenner 45MPHP10 auto-chlorine feeder : BBB Method
