Clogged Only Main Drain Pipe...HELP
Mar 21, 2017
2
Arlington Texas
While draining my pool, some debris has clogged my main drain pipe. So, I am needing to remove the Only Main Drain Cover (SMod 07017-0751) took out my screw driver...to discover the 2 tiny holes I thought were the screw holes WEREN'T. Not sure how to remove cover...?
Thanks
Are the screws the security bit type? They look like a Torx pattern with a pin in the middle. That's how my covers are. You'll need a security bit to remove it. Cheap sets are available at Harbor Freight...and they are cheap in price and quality, i.e. the little hole to accept the pin may not be in center.
