Thread: How to manually trip low voltage breaker on Pentair easy touch
    Feb 2014
    Santa Rosa Beach, FL
    44
    We rent our house in the summer and I want to figure out an easier way to disable the spa and heat mode. I currently turn the heater breaker off and flip the toggles on the back of the automatic valves.
    I have an easy touch 4. I have my heater connected to a dedicated panel breaker. I would like to be able to disable the spa and heat mode by manually tripping the heater breaker and the low voltage breaker for the automatic valves. If possible, how do you trip those small low voltage breakers?
    14x40 rectangular Grecian gunite pool with CLI Sunstone Pearl Cove Blue quartz finish. Pool has a 10x10 sun deck and 5 jet hot tub with 2 hp pump, 4K btu heater, 2 hp Intelliflo VS pump, IC-40 SWG Intellichlor, Globrite lighting, Racer cleaner with booster pump, Sand Dollar filter, Intellitouch with PC and android screen logic interface
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,281
    Re: How to manually trip low voltage breaker on Pentair easy touch
    F,
    In my mind, the easiest thing to do would be to open the electronics panel and simply unplug the Intake and Return valve connectors from the PCB...
    You might want to mark at least one of them so you will know which is which..
    Thanks for posting,
    Feb 2014
    44
    Jim, Thanks for the reply!
