Hello I needed some help and advice with my Pentair IC40 salt water generator.
This morning when I checked my pool chemistry my chlorine was zero. I noticed a red light on the flow display on the generator. Therefore I clean the generator using 50-50 acid mix to remove any calcium deposits.
After the cleaning the flow light turn green however, few minutes later it turned red again.
Also The top two lights for salt level are also flashing green and red.
My question is is it something I did wrong or is the salt generator malfunctioning. It's about two years old.
Here are some pictures of the display screen.
Thank you for any help.
