Hello to all,
I have the Hayward QC Robotic Shark. Started using it in March of 2015, and never became stuck on the main two pools drains. The drains are at a slight angle [pool depth goes from 4'.6" to 5'.6" in this area].
The spa is flat, and the shark always got stuck there. However, now that it's happening in the main pool, I did not have time to babysit while it works. Is there a fix for this that anyone knows? It does have the restrictor plate installed, but if I take out the plate, it climbs too high on the side walls.
If there is no fix, then what would you recommend? The warranty ends March 2018.
Thank you very much for your help and suggestions.
regards,
tstex
regards,
tstex
