Results 1 to 8 of 8
Thread: Green pool now cloudy
    Mar 2017
    Excel al
    16
    My pool was green and smelled like swamp water. I balanced the ph and added liquid bleach. 4 gallons. The water changed colors almost immediately but now it's super cloudy.
    Ph 7.2
    Al 60
    Th 110
    C 4
    CA not readable
    help!! I've added stabilizer in a sock to my skimmer
    Robin Inground pool 25000 gallons outdoor gunite Hayward sand filter Taylor 2006 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Green pool now cloudy
    Ok, time to do this, SLAM
    Mar 2017
    Excel al
    16
    I thought I did. The readings on my chlorine turned bright orange.
    DFW, TX
    24,974
    That link leads to a process to follow. Not just a one time addition of chlorine.
    If you want the long version for some extra light reading, that is here,
    Turning Your Green Swamp Back into a Sparkling Oasis
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,125
    Hi Rvirgil1,
    the slam is a process, not a one time shot. Here are the step by step instructions.
    Pool School - SLAM - Shock Level And Maintain
    The cloudiness is a good thing. That's what happens when you pour bleach into a pool full of algae. The cloudiness will get lighter and lighter as you continue the slam process, until you finally finish and your water is crystal clear.
    Quote Originally Posted by Rvirgil1 View Post
    Divin Dave,
    domct203's Avatar
    Jun 2015
    CT
    3,892
    Ph 7.2
    Al 60
    Th 110
    C 4
    CA not readable
    Welcome!
    If that was 10% chlorine you added 13ppm to the pool. Were your test results before or after adding the 4 gallons, and what test kit do you use?
    How much stabilizer did you put in the sock?
    As already mentioned, the pool needs a proper SLAM. Ask any questions you might have, but remember that the most important part if the SLAM is to Maintain that FC level until you pass all three criteria to end the SLAM. You will not believe how clear the pool water will be when you are done.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jan 2012
    'burbs of Augusta, Georgia
    8,557
    You need a better test kit. Your test kit seems to be lacking functions. I suggest the TF-100 avail thru TFTestkits.net $70, but will save you a fortune in the long run, I promise!
    Please tell us:
    FC
    CC
    pH
    TA
    CH
    CYA
    We need those levels to determine what you have and where you need to be.
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Mar 2017
    Excel al
    16
    I guess I better invest in one.
