Thread: Raised Spa/Jacuzzi - cracked tile line repair
    Hello,
    I have a crack around my spa/jacuzzi. I ripped off the waterline tile, cut a 2" band, and a secondary 3/8" band on the crack itself. I stuffed Quikrete hydraulic cement in the secondary band. However I still need to fill the primary band. It's 2" high and 1.5" deep. I have about 15' to cover and have a few questions. What is the spa wall normally made of? And what material an I use to fil this gap? It's behind waterline tile so wondering if I can I just use concrete?
    Any help would be appreciated.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,968
    Re: Raised Spa/Jacuzzi - cracked tile line repair
    I am in to watch this one and learn. I hope you get an answer soon.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Yes, concrete is fine to use there. Is there an expansion joint between the coping and the deck? Hard to tell, but if not that could be part of the problem.
    On the way out I noticed the title says raised. So, maybe not relevant.
    Thank you for the reply pooldv. Yes, I had the pool guys add in an expansion joint around the perimeter of our pool and spa.
    For waterline tile, I have thinset and grout from the pool store. If concrete is used and knowing hat its porous, would the grout or thinset prevent water for leaving the spa?
    DFW, TX
    24,974
    Grout and tile is what provides the waterproof barrier. Same as for a gunite/Shotcrete pool, which are also concrete, just applied differently.
    Thank you ... I appreciate your response.
