Results 1 to 8 of 8
Thread: 1st Test Results..... Thoughts?
    Jan 2017
    Sacramento, CA
    72
    Pool Temp 58 Degrees
    PH 7.5
    FC 3.0
    CC 0.0
    CH 400
    TA 120
    CYA 60
    Sacramento, CA - In Ground Plaster - 18,00 Gallons - Chlorine - 3HP Pentair Intelliflow #11018 - Pentair Clean & Clear Filter #160301 - Dolphin S200 Robot - TF100
    Jan 2014
    Brookhaven, MS
    45
    Re: 1st Test Results..... Thoughts?
    I'm jealous.
    Is your water clear?
    18x36 25k Gal Inground Vinyl Pool
    300lb Sand Filter / 1.5hp Single Speed Pump / Intellichlor IC40 SWG / Polaris 280 w/booster pump
    Jan 2017
    Sacramento, CA
    72
    Quote Originally Posted by rmasonjr View Post
    I'm jealous.
    Water is clear. in the past i have just used the basic tayler k1000 kit. This year i decided to step up my game and got the TF-100 kit. I am sure my CYA was worse, but with how much water i had to pump out this winter due to rain, that probably helped.
    Jan 2012
    'burbs of Augusta, Georgia
    8,583
    LOL, As I suspect you know your CSI is *On the Money*!!!
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Jan 2017
    Sacramento, CA
    72
    for comparison i ran to my local store and had them test
    PH 7.6
    FC 3.0
    TC 3.0
    CH 260
    CYA 60
    TA 90
    Every time i have them test they tell me my phosphates are too high. this test showed 500ppb. Is phosphates something i should be worried about?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Nope. They just want to sell you some chems.
    Jan 2017
    Sydney, Australia
    28
    FC is a little low for that level of CYA ...
    25,000L / IG / Pebble / Zodiac C170 SWG / Waterco CC75 Cartridge Filter / Hurlcon CX 240 Pump
    G'day from Sydney, Australia
    May 2011
    lebanon tn
    370
    Theoretically the phosphates act as fertilizer from r algae. Since the fc keeps the algae from vowing it's not an issue
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
