Thread: First time pool owner
    Feb 2017
    Keller, TX
    2
    So we thought it'd be fun to buy a new to us house with an existing pool. I've been reading through the pool school pages, have a TF-100 test kit, and think I have an idea on which direction to go. The pool water is clear, but there looks like there is some darker film growing on the walls. The filter pressure indicates it is still in the "clean" zone. More details on pool in signature.
    Test results:
    Water Temp = 65F
    FC = 2
    pH = 8.2
    TA = 160
    CH = 200
    CYA = 30
    Salt = 6600 (I think this is not correct, as the SWG controller thinks the salt level is low)
    CC = 0
    From reading thru Pool School, it seems as though my first steps are to:
    1. Drop pH to 7.2 with acid, then aerate to get the TA down to 70. May require repeating to achieve this... Then shoot for a pH of 7.6.
    2. Add bleach to raise the FC to 4.
    3. Do the overnight chlorine loss test to see if I have something growing, then SLAM if I do.
    4. Redo the salt level test and also check the SWG cell/controller to make sure it's operating correctly (currently set to run at 20% for around 6 hrs a day).
    Anything I'm missing? The SWG control panel has a sticker that says the salt level should be 2700-3400 ppm, does that sound correct?
    Thanks, Ryan
    18,000 gal IG free form pool w/spa (2004 install), pebble finish, Jandy CL460 cartridge filter, Jandy ProSeries Stealth pumps (SHPM2.0 for pool, SHPM1.0 for spa), Pentair Booster Pump LA01N, Hayward T-Cell-15 SWG w/Aqua Logic controller, Jandy LX heater, Spa Blower 1-6316220F, Kreepy Krawly Legend pressure cleaner, Taylor TF-100 test kit + K-1766 salt test, city water
    May 2011
    lebanon tn
    370
    Re: First time pool owner
    Turn swcg off for oclt
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP! Congrats on the new pool!
    Yes, 2700-3400 is a normal salt level
    You're going to want to run your pH at 7.8 during normal operation, it will want to be there anyway.
    Feb 2017
    Keller, TX
    2
    Thanks! I'll post back numbers after running tests again...
    Jun 2007
    Houston, Texas
    212
    For a SWG, ideally you want your CYA to be between 70 - 80. Also your FC should be 4 - 6ppm. You want to check that your SWG is generating chlorine correctly. My test kit shows a high salt level as well even though my system and the local Leslies are much lower. I just go with what my system says as it seems to work.
    The PH is going to drift up as you use the SWG. Adjust your pH to 7.2-7.8 and not any lower. Monitor your pH and when it climbs to 7.8 add acid to lower it back to 7.2 - 7.5
    Pool School - Water Balance for SWGs
    Pool School - Chlorine / CYA Chart
    36,000 gallon IG Gunite (40 x 20), 1.5 HP Hayward pump, Pentair Nautilus NS-48 DE filter, 2 skimmers, 12 - (2 x 20) Fafco Solar Panels (Goldline controller not hooked up yet), Hayward Swimpure Plus SWG, Blue Pearl Robot cleaner. New Dr. Wellness X-12 standalone Lifestyle Spa.
