Results 1 to 7 of 7
Thread: Accidentally added DE earth to a cartlidge filter!
    Mar 2017
    Riverside
    5
    need help! I am a new pool owner and I did the mistake of adding DE EARTH to a hayward cartridge filter. once I realized that I wasn't supposed to do this I cleaned the cartlidges, but I an now seeing some DE in my pool and the water is cloudy. What are my options ? thank you
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    168
    Re: Accidentally added DE earth to a cartlidge filter!
    Vacuum and wash filters again. I can't think of another answer but that maybe would work. Keep an eye on pressure. You may have go to clean 2x Although no one would knows how much you put in ?
    Experts Will Chime in
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    Mar 2017
    Riverside
    5
    I put about 4 pounds into the skimmer.
    I completely cleaned the filter, but I'm still seeing a little DE powder stuck to the cartlidges.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    That isn't surprising, and you may find reduced performance from your carts after you can't find any more at all. Some may embed itself into the fibers enough to create a need for replacing the filters, but I wouldn't do that until I was sure I got all the DE out of the pool.
    Essential Links:
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    No worries, clean and utilize till they don't perform.
    Sep 2016
    Escondido/CA
    641
    Maybe a little backwashing will go a long way.
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    Apr 2011
    Murrieta, CA
    2,360
    Cartridge filters get washed/rinsed with a hose, no backwash option.
