CAN'T KEEP THE COVER ON.
24' Above ground pool. We always put on a 28' cover, based on past experience. The edge of the cover has a cable thru the grommets, PLUS we put a second cable right at the top of the pool. Additionally, the cover is clipped all around the edge. I fill the cover with a few hundred gallons of water. There is a balloon (pillow) in the middle under the cover.
The pool's location is in an open spot, so any normal wind is directed right at it. Yesterday we had a wind storm, with gusts topping out at 70 mph. I spent the entire day replacing the blown off clips and tightening the cables every 20 minutes.
When it gets windy the cover billows up like a balloon. When a gust pops it up violently, it pops off the clips.
We are in a freezing climate so I can't keep the water level high or add more water to the cover because it may crack the fittings.
The problem is only prevalent when it thaws. If I have a full layer of ice around the top, the weight of it holds down the cover. When it thaws the water is forced to the leeward side, and hence the billowing of the empty side.
Is there a better way to secure the cover?
