Results 1 to 7 of 7
Thread: Can Organic Mud Create Algae
    Mar 2017
    canyon country, ca
    2
    Angry Can Organic Mud Create Algae
    We recently had a bad wildfire (welcome to California) and then mud slides. The first slide was all of the organic ash from the fire. This "mud" made it to the pool. There was about eight inches of mud at the bottom.
    We drained the pool and did an acid wash. When we refilled the pool we noticed yellow/brown stains arond the sides of the pool at the bottom where the mud was. we tried a chlorine treatment, but it's still there.
    The stains appear to be growing, but it is hard to tell as the stains are visable when the sun shines, but almost disappear when a cloud blocks the sun. Now the stains appear on the walls of the pool (lighter than the stains at the bottom).
    My pool tech thinks I need to replaster, but I am thinking it is Mustard Algae and should be treated.
    Any thoughts?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,994
    Re: Can Organic Mud Create Algae
    Welcome to TFP
    The first question is what are your chemical levels?
    FC
    CC
    pH
    TA
    CYA
    CH
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mar 2017
    canyon country, ca
    2
    I was afraid you were going to ask that . I do not have any testing equipment just yet. I have a pool service that normally takes care of the pool. I will have to go out and get a testing kit. Is there a particular brand you recommend?
    My main question was: Can the organic material in the mud (oak, sage - Calif Chaparral) produce stains that acid wash can't remove and can this mud cause mustard algae?
    I will get a test kit and get the answers you need.
    Thank you for your help!!!
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    In regards to a test kit we recommend the TF100 from http://tftestkits.net/splash-page.html or the Taylor k2006C available from amazon. Both have to be ordered online
    Organic material itself wont cause algae in the pool. However it would have placed a significant drain on your chlorine reserves. Once the chlorine got low, then the algae would have had a chance to get a foothold
    The stains could be organic in nature or could even be iron deposits from the soil.
    We have treatments that work for both of these scenarios, but need careful chemical management, using the results from the test kits suggested above
    You could try the tests in the link below to see if you can identify the stain.
    https://www.troublefreepool.com/cont...d-metal-stains
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
    Jan 2012
    'burbs of Augusta, Georgia
    8,561
    Actually, for folks who live out west in the US, Pool Supplies, Spa Supplies and Parts carries the TF-100. It would ship right within California so you'd get it faster.
    Water Testing - TFTestkit TF-100 Seven Test Kit - TF-100
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Mud is just that...mud. Mud doesn't cause algae--------unless it contains algae spores. Just because your CCs go up doesn't mean you have algae due to the mud. I'd get that test kit, brush it, and slam it if necessary before anything drastic. The longer the mud or organic material such as leaves sits there, the more likely it is to stain.
    May 2011
    lebanon tn
    370
    Oaks, fears, and redwoods I believe all have tannic acid in them. Creates a tea colored stain. So one answer is yes mud can cause stains. And can act as food for algae and create a bloom if fc isn't maintain d. So you could have so her
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
