- Jun 15, 2009
- 3
I just added the proteam supreame start up kit this spring witch was 10lbs proteam supream and 10 lbs ph down. now I stumbled acros this site and was reading on the efects of borates, and I realize 10 bls was probobly not enough. My question is I have a 13000 gallon pool according to the pool calculator I would need to add 47lbs of borax. acording to proteams dosage chart I would need 45 lbs assuming 13500 gallon pool. so should I just add the remaing 35lbs in borax and correct the ph with acid?
