Results 1 to 8 of 8
Thread: New to SLAM - First test is here
    Jan 2014
    Brookhaven, MS
    45
    So, I got started on my pool *before* finding out about SLAM, so my readings appear a little out of whack.
    I had already put in 10g of liquid chlorine from Wal-Mart the week before.
    I ordered a Taylor K2006 and did my first complete test last night - here's what I had:
    FC 2.2
    CC 0
    pH 7.0
    TA 40
    CH 60
    CYA <30
    SWG=OFF
    Since my CYA is non-existent, I dont know what my target/shock FC should be.
    My pool is not green at all. I suspect the original 10g of chlorine did the job.
    I can see to the bottom in the shallow end and can just barely make out the drain in the deep end.
    This morning, I added 2gal of liquid chlorine just to keep the FC level up.
    I'm especially worried about the CYA.
    I'll do another complete test tonight which will be 24h after the first test.
    Any pointers?
    18x36 25k Gal Inground Vinyl Pool
    300lb Sand Filter / 1.5hp Single Speed Pump / Intellichlor IC40 SWG / Polaris 280 w/booster pump
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: New to SLAM - First test is here
    Are you registering some CYA, or is the tube clear to the top? If you are reading some, I would call it 20 and SLAM, otherwise I would add enough to aim for 20 and then SLAM.
    Be sure to read this article a few times, SLAM is not a blind, one time dosing of chlorine, it is a process:
    Pool School - SLAM - Shock Level And Maintain
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jan 2014
    Brookhaven, MS
    45
    Thanks Mr Bruce - it is definitely clear all the way to the top - the black dot at the bottom of the tube never went away
    The SWG chart doesnt list 20 as a CYA - should I still use 24 as the Shock FC target?
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,282
    When SLAMing you shouldn't be using your SWG, so no need to refer to the SWG portion of the chart for now. Just using the top part of the chart (non-swg) when you are SLAMing.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jan 2014
    Brookhaven, MS
    45
    Ahhh - that makes sense. Thanks!
    Jan 2014
    Brookhaven, MS
    45
    I finally got my pool to SLAM level I think - I am still unsure about my CYA levels - there are none:
    FC 23
    CC 0
    pH 8.0
    TA 60
    CH 50
    CYA <30
    SWG=OFF
    Where in the SLAM process do you add CYA?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    If you are sure about the CYA being low you can use pool math to find out how much you need to get to 30. Put it in a sock and hang it in front of a return. Give it a squeeze or two whenever you think about it. It can take a little while to dissolve. Once it's all gone wait a day and try the test again.
    Of course, continue the SLAM as you have been. Adjust FC target as CYA changes.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,282
    FYI, the CYA test is light and temperature sensitive. The water needs to be room temp. The test needs to be performed outside in the sunshine with your back to the sun while holding the vial at waist level. You can pour the sample back and forth if you are unsure.
    Karen
