What is everyone setting their solar controller temperature differentials at?
I'm trying to figure out a good setting that provides efficient heating with minimal valve cycling. The temp differential that I am referring to is the difference between the panel temp which is basically air temp at the panel compared to the water temp of the pool.
I currently have my start temp differential set at 6 degrees and the stop differential set to 2 degrees.
