Hello,
I am just wondering if someone can advise if my theory sounds like a good solutions.
I am trying to add a "Smart Switch" that works off WiFi or Bluetooth. Seems like all the ones at the local hardware store need a neutral wire. My neutral wire from the pool light goes into my GFCI Service Outlet. Can I just come from the same connection (where the Neutral wire is connected) and take it to the new switch? My set up is attached as best I can display.
Again, I'm wondering if it's okay to just go from the same neutral wire connection on the GFCI and take it to the switch?
Chris
Chris
