Results 1 to 10 of 10
Thread: Pool Tile Polish/Protectant
    Jun 2016
    Scottsdale, AZ
    32
    Hi everyone,
    Does anyone have any suggestions on what we could use to polish/protect our pool tile?
    Something like car wax?
    Apr 2015
    tucson, arizona
    1,312
    Re: Pool Tile Polish/Protectant
    Coating Systems Laboratories, Inc. - Diamondclear Products, this is one product designed for pool tile
    Jul 2011
    Las Vegas, Nevada
    139
    TPS protectant is what I covered my tiles with and it works great. We just finished our second pool build and we are using it on this pool too.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    I dont get excited much about pool products in general, but that looks potentially very good if it works. Something that could help, even with the best pool balance upkeep. Waterfalls, and dark tiles come to mind.
    Essential Links:
    Jun 2016
    Scottsdale, AZ
    32
    Thanks y'all. I'll grab some of that stuff.
    JoyfulNoise's Avatar
    May 2015
    14,083
    Being a silicone material, it's going to leave a film behind. They say it doesn't yellow or crack but I'd like to see more info on that. Here in AZ the sun and heat are so intense, I would be very wary of applying any coating to my tile. If sun exposure isn't as much of an issue, I suppose it could work. Silicones, once dried can become very hard to remove from surfaces. It would be interesting to see some before and after shots if you could post those.
    Matt
    BeachSunH20's Avatar
    Feb 2017
    Las Vegas NV
    143
    I am curious if the TPS would be good to apply to tile in Las Vegas, with our sun/heat....?
    Built 9/2016 -10k pool, IG Concrete pool/spa - travertine coping/deck - All Pentair Equipment - Pentair Clean & Clear Plus Cartridge filter-Master Heater 400,000- Pump Intelliflo vst - color plaster - rebel cleaner- Auto -tablet-Chlorinator -Screen logic connect- variable pump - Test Kit Taylor 100.
    Jul 2011
    Las Vegas, Nevada
    139
    I used it on my last pool we built here in Vegas, and I just finished our new pool and we used it on this one too. It never turned yellow, cracked or flaked off.
    Feb 2017
    Las Vegas NV
    143
    Quote Originally Posted by Owner/Builder View Post
    I may try in a few extra tile I have, i think I would have to drain some of the water to get to the tile.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    If it will take Vegas heat and not crack or yellow, it ought to work just about anywhere on this continent.
    Essential Links:
