Bromide oxidizer - Chlorine vs Bleach
I did a lot of reading about oxidizing bromide and some reason I thought I read chlorine acts a slightly different then bleach when you add it to the hot tub. Sure they both oxidize the bromide ions into hypobromous acid but they have different properties that might be better at breaking down (x)?
Is there any difference in the 2 when using them as an oxidizer/sanitizer?
Should I alternate them every time I shock my hot tub?
Can I mix the 2?
Can I mix the 2?
