Hi Everyone,
I had a new pool installed about 4-5 months ago. I've been using this forum to keep pool maintained but this is first post. I continue to add about a quart of acid every other day or so to keep PH in check. It will go above 7.8 after about 2-3 days. I've not been too concerned about this as I've read multiple times on this forum this is normal and expected, especially with a new SWG plaster pool. My concern is that although TA has remained on lower end, it has gradually lowered over the last three months from 60 to 40. I think this is due to the acid being continually added. I have not done anything to raise it because I keep my SI in proper range due to my calcium hardness being a bit high. My CH is 550 and has gone up slowly from around 450 to 550 over the last three months. In summary, I have what I believe to be a low TA, high CH but they appear to be cancelling each other out and keeping my SI in ok range. Now that the weather is turning warmer and I just turned the heat pump on, I'm considering whether or not to adjust the TA and CH levels.
Before I take any action, I'm curious if there is any harm to equipment or plaster in maintaining the balance I have right now (Low TA, High CH)?
If it is better to adjust TA and CH to proper levels, I am considering the following plan:
Day 1: Remove 10% of pool water and replace. My city water is TA 190 and CH 230. Hoping this gets CH to 350-450.
Day 2: Raise TA using sodium bicarbonate to get to 70. The water replacement from Day 1 will raise TA as well so will be curious how much more I have to adjust, if any.
Day 3: Adjust PH back to proper range.
My current measurements are:
Water temp: 73F and rising with heat pump running
Ph: 7.5
FC: 1.8ppm (I turned up the SWG yesterday to raise to 3-4ppm)
TA: 40
CH: 550
CYA: 40
Borates: 40
Thanks in advance for any advice you have for me.
Regards,
Chris
Ph: 7.5
TA: 40
CH: 550
CYA: 40
Borates: 40
Regards,
Chris
