Hi All!
I have been researching and reading posts on this site for a few days and am excited to getting around to post! My wife and I (plus 3 kids: 6 yrs, 3 yrs, and 4 mo old) are am in the process of deciding between 2 PBs and I would appreciate any and all feedback from everyone. I feel like we’ve been going through this process all alone and feel very much relieved to have found this site as a resource. I'm a first time PB - second time pool owner - pumped about the decision and ready to get this show on the road! Feel free to comment on design, function, or anything else that you see fit - I appreciate all of your help!
PB 1 Design and specifics:
Pool/Spa Area
Pool Perimeter 104LF
Pool Area 548 SF
Pool dimensions 34'L x 21'6"W (widest point)
Spa Specs: 28KF Peremeter, 48SF Area, 6'x8' Length/Width, Height=Flush, Zero edge spillway ($10/SF glass tile allowance), countoured multi-level benches, 6 Hydro therapy jets
Steel/Plumbing/Gunite:
4 bar bond beam #4 rebar, Grade #60
Walls floors #3 rebar, Grade #60
Alternates in floors
Stainless steel ties
Hydraulic system all schedule 40 PVC
Automatic fill line w/ overflow to maintain water level
Pressure test hydraulic system
Pneumatically applied gunite
Bond Beam 12"w x 18" depth (top portion of shell)
Walls/Floors - 6" to 8" thickness
5000 to 6000 psi (NSPI standard is 3500 psi)
Lifetime warranty against pool shell leaking
Pool Equipment (all pentair includes 3 yr parts/labor warranty):
Pentair 2HP whisperFlo Pump (they are upgrading this to the variable speed)
1 HP SuperFlo Pump (water feature)
Clean and Clear 520 Cartridge Filter
Master Temp 400, BTU Heater NG (gas line included)
Silencer Air Blower
Easy Touch 4 Function w/ Wireless remote
Rainbow 320 Inline Chlorinator
Pentair Rebel Pool Cleaner
Intellibrite LED White Pool and White Spa Light
All plumbing is 2.5" schedule 40 PVC
Others:
18" raised center beam wall and left/right wall 12" raised
3 travertine scuppers
6" tanning ledge w/ 3 bubblers
Pebble sheen (L1) w/ 10 yr warranty
PB 2 Design and Specifics:
Custom formal pool/spa combination 34’ length x 16’6" avg. width overallsquare shape spa, 0" elevation with tile wall cap over wall inside pool area, 50sq. ft.
103’ total perimeter with 12"x12" travertine coping.
Approx. 535 sq. ft. of water surface in pool
Recreation pool - depths are 3’6” x 5' x 4’ (these depths are approximate and can be adjusted)
CONSTRUCTION
Standard steel reinforcement throughout pool – (4) ½” bar continuous throughout beam, ⅜” bar in walls and floor
Pool structure to be 100% gunite with continuous bond beam
Step entry off of bathing shelf as per plan.
Bathing Shelf step entry at spa side as per plan
Elongated bathin shelf off patio w/ telescopic mini geyser
17 linear feet of 12” raised beam with Ledge Stone facing
16 linear feet of 6” raised beam with Ledge Stone facing
(2) 16"x16" square pedestals 12" raised w/ travertine cap
(2) 16"x16" square pedestals 18" raised w/ travertine cap
Spa to be level w/ cut 12"x12" travertine coping to the outside w/ T-Brick flush to the inside and stacked open spillway and ledge stone facing surround
Spa to have safety rated channel drain in floor
All plumbing is 2” schedule 40 PVC pressure tested
(2) Two Hayward skimmers plumbed with separate line back to equipment
(2) Two V.G.B.A. safety main drains 3’ feet apart plumbed with separate line back to equipment.
Separate in wall V.G.B.A. safety in wall suction for water feature pump.
3/4” fill line inserted in tile band operated by a gate valve and pool miser auto fill.
2” Overflow outlet tied into 4” area drain
4” area drain line run to street, (6 to 8) heads, applicable down spouts tied in.
Electrical hook-up from main to equipment located on right side of house
GFI electrical plug/breaker for lights
All gas line from existing meter to heater included (Meter upgrade by homeowner & Center Point Energy.)
(2) Two clean-ups – one after gunite and one after plaster
TILE, COPING, DECKS & PLASTER
6” tile band around pool in your choice of any standard tile
Ledgestone facing to the beam and wrapped around the spa
Approx. 485 sq. ft. of new CRS (Comfort Coat) textured decking as per plan
Concrete for new deck will be tied with 3/8" steel rebar on 16" center for added strength.
Satin Matrix tier II small pebble finish (cost value $3,900)
EQUIPMENT
Hayward 5030 Quad Cluster cartridge filter
Hayward Variable speed pool pump
Hayward Super II 1.5 hp pump for water feature
Hayward Lo-Nox induced draft heater – 400,000 BTU
Hayward Tiger Shark robotic cleaner
On Command controller with Aqua Pod Remote
Polaris 1.5 hp QT blower
(6) Six Hayward – 3 oscillating and 3 adjustable
Hayward Crystal Logic – (1 pool, 1 spa) low voltage White LED lights with 300 watt transformer
Swimming pool equipment on gunite pad.
Pool/Spa Area
Pool Area 548 SF
Silencer Air Blower
Others:
CONSTRUCTION
EQUIPMENT
