I know you are supposed to shut the pump off, release the air from the filter and then drain the filter (I have slide valves to shut the water flow) in order to remove and clean the cartridge. I have a Pentair clean & clear cartridge filter.
However, I was reading a lot of problems and issues people were having from either breaking the cap by trying to open it or cross threading.
My question is why do you have to drain the water out of the filter to remove the cartridge and clean it?? I had an intex cartridge and would just plug the pool and remove the cartridge even with water in the filter????
If it is necessary is it a better idea to just replace the drain plug with a spigot with an on/off handle?
Thanks!
Thanks!
