This is brand new.......if it was me, I would DEMAND a new replacement, to me, this does not look like a manufacturing defect. The stone should have levelled with a screed and ideally run a plate compacter over it. By screeding, I mean they can use a 2 x 4 on edge and slide it back and forth to level the stone sub base and they can put a level on the 2 x 4 to make sure they are in the ball park for level.
Did the pool builder put that wood and jack there, then begin filling the pool? If so, that is definitely was caused this delimitation split on both sides of the jack.
Also if that is the case, you will have a hard time for the manufacturer to stand behind it, if I was him, I surely would not warranty this installation method. I am sure there is a detail site preparation method that calls for a level surface that completely supports the shell.
This looks like PB inexperience if he put that jacking arrangement BEFORE backfilling.
There will always be a bit of settling when you will the pool with water weighing 8.3 lbs/gallon but if the installation is correct, the settling after fill will be minimal, most likely invisible and not cause any structural damage. That takes a lot of force to split FG like that.
Do your best to tell the PB you want this shell replaced.
At a bare minimum, if the PB is NOT going to replace the shell, then YOU contact the manufacturer yourself, tell them what happened and send the pictures, get the manufacturer recommendation what to do.
I have a 45 year career in Oil and Gas, and when we have an equipment or installation issue, the manufacturer recommendation is the RULE, it overrides what is in the Contract and Specification because ultimately it is the manufacturer that is going to support the warranty, so we follow his recommendation.
Ask the PB what he is going to do?
If it doesn't meet your satisfaction, let him know you are going to contact the manufacturer.
Kimkats......is one of the best Experts here........he offers you sound advice......FULL STOP.......on any further work until this is resolved.
See where that leads you first and post it......let us know how this is going.
It probably can be repaired by a qualified FB guy, then you demand an extended warranty from the PB but the problem with that is these guys go in and out of business like you change your socks. How long has this PB been in business?
Check the BBB Better Business Bureau and see if he has a history. You can do that right here online, it is free and easy. If you need help with that, let me know.
