Thread: Newbie (to the forum) saying Hi!
    Just wanted to say hi. I am new to the forum and just donated to be a lifetime member.
    I was surfing the forum last night and found so much good info here, that I just had to become a donating member. I look forward to asking all kinds of questions, as I just converted from Baquacil (for the 2nd time) to a salt pool. I am just getting my salt added to the pool and balancing the water (CYA, PH & such). Wired in the SWCG today and should have it turned on and running tomorrow.
    Nauidvr1
    14' x 28' inground concrete pool - 14,500 gallons
    Hayward Cartridge filter C-1100
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Re: Newbie (to the forum) saying Hi!
    Welcome! I have to ask; Why the two conversions?
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    DaveNJ's Avatar
    Toms River, NJ
    520
    Welcome to TFP,
    Pool School has great info on water balance for a SWCG pool. Also, a good test kit is a must. There's another article on test kits. I like the one in my signature.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    Got some pix of your pool?
    You're done SLAMing when:
    Quote Originally Posted by No P in my ool
    Dear No P in my ool - the reason for the 2 conversions: When we first bought the house (was my wife's Grandmothers) 15 years ago, I had to rebuild the entire pool (new liner, pipes, pump, filter & fresh water). When we put the water in the pool I chose to use Baquacil and had nothing but good luck for 10 years, then the problems began. So I converted to chlorine for 2 years, then the liner had to be replaced (did this myself). I thought since I had such good luck with Baquacil for the first ten years and the water was going to be new again (no Baquacil saturation or build up) I would go back to Baquacil - bad move, I had nothing but trouble for 2 years. So that bring us up to now - converted this year when I opened the pool and decided to go with a SWCG, I just wish I would have read this forum before I bought a Pentair IC40, I probably would have gone with something else (one of the more recommend ones here on the forum).
    Quote Originally Posted by Butterfly
    Butterfly - I do have pics of the pool, I'll post some in a few days.
    Quote Originally Posted by DaveNJ
    Welcome to TFP,
    DaveNJ - I ordered the TF100 right away after reading the board and becoming a lifetime member. I hope to receive it this week.
    Arizona
    925
    Hi and welcome.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
