See attached for water chemistry .Water is 6 weeks old with spa marvel added along with borates in the rough area of 60ppm
.I used lithium hypochlorite in the beginning and switched to sodium hypochlorite 10.8 %about 2 weeks ago for sanitizer and used about 10 - 1 inch trichlor pucks in the floater during the 6 weeks. Questions
1) cya is greater than 169 if test is accurate, can I reduce it àny other way than drain and refill as it is -10*C in Ontario now.
2)can I burn off the combined chlorine or should I just leave it
3) under more normal senerio what conditions should a slam be considered and what would be the normal ppm to obtain.
Fc 4.95
Tc 8.37
Cc3.42
PH 8
Hardness 254
Adj Alk 44
Cya +169 ???? Could this be wrong?
temp 101*F
Tds 1600
Borate 60?
Fc 4.95
Tc 8.37
Cc3.42
PH 8
Hardness 254
Adj Alk 44
temp 101*F
Tds 1600
Borate 60?
