- Jun 11, 2009
- 8
The CYA was determined at the pool store, she mentioned that "it wasn't the highest she'd seen" so I'm assuming that they could read it higher?
What I did is figure out the surface area of my pool, then figure out how many gallons per vertical foot. My pool's area is about 600 sq ft, so each vertical foot is 600 cu ft, and there are 748 gal per 100 cu ft, so each vertical foot is 6 x 748 = 4488 which I round to 4500.threekidsmum said:We started the submersible last night, and we have removed 2 & 3/4 ft of water. How do I determine how many gallons that is? Is there a standard equation for it?
anonapersona said:You can note the water meter reading as you refill and when you end to find out how much you put in on the refill.
