I’m getting ready to replace an old single speed pump and understand that with my simple pool setup I could probably get away with a 2-speed pump but I like the additional flexibility of the VS pumps.
I’m in Phoenix. My simple in-ground play pool was built in 97 and is Pebble-tec, 12,000 gallons, one typical skimmer with single floor drain combo, a dedicated suction line for a Nautilus cleaner (Jandy-type valve at pump inlet to control suction) and a small adjustable spray head for summer cooling. 3 returns, non-SWG, no heater, no solar, no water features.
My equipment is a single-speed ¾ HP 220V Hayward SP3007 pump, a TR60 sand filter and a Jandy-type valve to divide the suction between the Nautilus sweep and the skimmer/floor drain. I use a typical Intermatic grey box timer with two run periods daily and adjust the run length with the seasons.
I use liquid chlorine and the TF100 test kits for balancing. Bathing load is low. Usually just the wife and I.
I’m looking at the newer Max-Flo VS-S2303. I like that it can be run stand-alone at 8 speeds or with several automation choices. I like the swivel or remote mount option on the control panel. I’ve heard that compared to the older 2302 model this new one is slightly less efficient but I hope that means this one will have better reliability overall. I will self-install and take the opportunity to re-plumb the whole filter area so that it flows better and not so close to my A/C unit.
The one variable that I might mention is that I have a grid-tie PV solar system and generate close to 100% of our power needs. Any load I can reduce at the pool will build our energy credits that help keep us from purchasing additional power for cooling during the summer when the panels are hot and less efficient. The pool pump is the last thing I can easily upgrade to reduce our energy use.
We’ll be staying in this house for at least 20 more years if not more. These are all long-term strategies so I’m not shooting for a short payback. I’m trying to make good choices now that will pay off in the long run through efficiency and reduced maintenance/replacement. I don’t mind paying for quality as long as that’s what I get.
Comments from anyone in a similar situation or that has made the swap to VS with what I consider a very basic pool setup?
Thanks!
Thanks!
