I have noticed that when I forget to rinse out the chlorine test graduated cylinder before testing, the FC shows low and the CC high. Then I do a cylinder-rinsed-out-with-pool water chlorine test, and the results show a higher FC and lower CC. Here is today's NO RINSE and then RINSED results:
NO RINSE FC 2.5, CC 1.0
RINSED FC 4.0, CC 0.5
Each time I forget to rinse, the results swing the same way. I suppose CC products build up on the cylinder over the 24 hours it sits in the box. I rinse the cylinder AFTER testing with tap water, and only shake it dry. Thus it is put away moist.
Just thought I'd mention this, as I believe it has led me astray before I realized what was going on.
