My ColorQ readings are almost always consistently lower than my TF100 readings (FCL might read 4.5ppm when actual is 6, PH might be 7.4 when actual is 7.6, etc), but the magnitude difference is fairly constant. The biggest variation is CH which reads about 100 ppm lower (200 vs 300). Basically, I can look at the Color Q readings and know what the TF100 will read before I take the measurements.
