Is this a bad idea to convert to a 12v system using my existing 120v wiring and pentair fixtures in my under water lamps? I read that gfi is useless at 12v, so that makes going to 12v dangerous or against code?
i recently replaced my bulb and a new silicone gasket and I noticed a little water getting into the housing. Im
buying a new gasket (not silicone this time) to try again and thought maybe going 12v would be safer? Also I was told not to put silicone on these gaskets, just confirming this as well.
