Yup. Borax.
A fountain or source of aeration would be good too....while free, aeration would will take too long.
Why? Chlorine neutralizer will add sulfates to your water. Also, why bring the chlorine down ot 0? You need to keep chlorine in your water or the pool will turn green!jjoshua said:This afternoon, I added some chlorine neutralizer to get my chlorine readings back down to 0 so I can start fresh tomorrow.
It doesn't work that way. You need more chlorine, not less. Adding chlorine neutralizer was a waste of time and money. It isn't going to do whatever it was you thought it was going to do. It is just going to mean that you need to use yet more chlorine.jjoshua said:I just wanted to get everything (including CC) back to 0 so I can figure out what's happening when I add chlorine again.
Correct! You most likely have excess neutralizer in the water right now so the first chlorine you put in will get used up oxidizeing the excess neutralizer. It's jut a waste of time and money.JasonLion said:It doesn't work that way. You need more chlorine, not less. Adding chlorine neutralizer was a waste of time and money. It isn't going to do whatever it was you thought it was going to do. It is just going to mean that you need to use yet more chlorine.jjoshua said:I just wanted to get everything (including CC) back to 0 so I can figure out what's happening when I add chlorine again.
