Have been using the TFPC kit throughout the summer and am finding a common problem with PH and TA adjustments. For instance, today's test gave me these numbers: FC=3, Ph= 7.8, TA=90, CH=225, CYA=50. PoolMath indicates pool needs chlorine and baking soda to adjust the FC and TA numbers. What I am finding is that when I add the baking soda to bring up the TA, it throws my Ph up too high, which is easy to do because it is on the top end of good range. Typically at that point, PoolMath indicates pool needs Muratic Acid to bring the Ph down, but because the TA is on the low end of normal range, it adjusts TA too low. It has been a constant cycle. Please help me with better way to balance the two, or let me know if there is something i could do better. Thank you.
