I have a Waterway Pump Model SD-15-1N11CC The On/Off Toggle Switch broke off. I'm trying to find a replacement switch online. So far haven't found anything. Anyone know where I can buy a new switch?
If it is easy to get into the pump I would remove the switch as many manufacturers use off the shelf parts from other vendors and often times the part number is on the part. If that fails you you can always just hot wire it and wire an external switch on the power line going into the pump.
My Googling had failed me too. UNTIL about 5 minutes after I asked the question here and then I finally found it. Just in case anyone else is looking for it and having problems finding one I'll post the link here. Who knows.....I may need this link again as well.
