There won't be any scale in that cell with CSI -0.3 to 0! Yes, I agree that as the cell ages you need to be aware that false low salt errors are a common failure mode.
Good info here. I added 150lbs last week and let the system run 6hrs/day for the last week (in floor heads) - stabilized at 3000ppm and fired up the SWG at 40% today.
I let Titan do all of my (over) thinking!!!!!
Come on guys, it's the OCD people like me that made space travel possible, lol!
I kicked my salt cell on yesterday @ 50% with a FC level of 5.5ppm, 6 hours later I tested at 6pm and the FC was @ 6.5PPM. I dropped the cell to 40%, my pump is running @ 1500 RPMs from 8am-5pm. Will test again this afternoon, but I think with a longer pump run time I can reduce the cell usage, well we shall see.
You've got it backwards. You want to increase output and decrease pump run time. Pumps typically use more energy than the cell so it's better to push the cell harder than run the pumps longer.
I thought running 8-5 was adequate run time for the pump? I guess I can cut back on the run time but I like the pool clean and it's crystal clear, perhaps I will try cutting back on the run time? For now I just want to be able to maintain FC at 5ppm. I will see where FC is when I get home from work.
See this study -
http://consensus.fsu.edu/FBC/Pool-E...4_study-efficiency_of_circulation_systems.pdf
Basically shows the old concept of required minimum turnovers is false and that most pools achieve adequate levels of sanitation and cleanliness with just a few hours of pump run time.
Ok, just tested the salt with the taylor k1766 kit, the test said the water is at 2,800 ppm, my salt cell says 2,900. So do i add more to get to 3000ppm?
Yes its making Chlorine. I guess i can leave it. I will be adding acid due to new plaster. Just thought i should be at 3000.
