Results 1 to 13 of 13
Thread: Recommended numbers for my pool
    May 2009
    Florida
    45
    I read through pool school and was wondering if those numbers would be sufficient for my pool.
    I'm targeting......
    FC 3
    PH 7.6
    TA 90
    CH 300
    CYA 70
    Borates 50
    Those numbers give me a CSI of -0.26
    Pool specifics are in my signature and also run a water fall when pump is running. I'm noticing a significant PH rise though with the fall on when the pump runs so I may turn the fall off more often to help stabilize the PH.
    Any recommendations on numbers are welcome.
    14,275 gallon inground ~ Pentair Cartridge cc200 ~ Pebbletec Tahoe Blue ~ SWG Intellichlor IC40 ~ Pentair Whisper 2hp ~ Taylor FAS-DPD Test Kit
    Jan 2009
    Cupertino, CA
    1,966
    Re: Recommended numbers for my pool
    The Chlorine/CYA chart in Pool School gives a minimum FC 5 for CYA 70.
    --paulr
    BBB "Intermediate Swimmer"
    May 2009
    Florida
    45
    Would a higher TA help stop the upward drift of PH with the SWG and waterfall?
    Jan 2009
    Cupertino, CA
    1,966
    No, you need a lower TA to reduce the rate of pH rising.
    You said CSI was -.26, which made me nervous about suggesting you reduce TA any further. But I double-checked your numbers in the Pool Calculator; to make everything work out it looks like your water temp must be about 60F. CSI will go up as the temp goes up, so lowering your TA is probably okay.
    --paulr
    May 2009
    Florida
    45
    My water temp is about 81F.
    May 2009
    Florida
    45
    Keeping the PH at 7.8 and TA at 90 would give me a CSI of -0.1 or even allow me to lower the TA more with the water feature running.
    Is 7.8 too high though or should I keep it at 7.6?
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Kenny,
    Have you seen the Water Balance Tips for SWGs in Pool School?
    Also, Waterbear has a tip page here that may help answer your q's:
    water-balance-tips-for-a-swg-t3663.html
    You're done SLAMing when:
    Quote Originally Posted by PaulR
    This is a SWG pool, so the minimum FC is 3 for CYA of 70.
    You actually want the CSI to be a little negative, -0.3 or a little lower in many case. The CSI inside the SWG cell is much higher than it is in the pool in general, and the same is true inside the heater (if you have one).
    I would aim for a TA closer to 70.
    May 2009
    Florida
    45
    Thank you! Is CH ok at 300 then with the lower TA?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by kenny
    Recommended CH level is between 250 - 350, so I'd say you're perfect.
    You can read all the Recommended Levels in Pool School.
    Jan 2009
    Cupertino, CA
    1,966
    Ah, missed that--kenny didn't give a salt level and it didn't click that Intellichlor is a SWG. Oopsie!
    --paulr
    Butterfly's Avatar
    South Carolina
    10,045
    Kenny, it would be good if you added SWG along with Intellichlor IC40 in your sig.
    Those of us that do lots of reading could use all the help we can get!
    May 2009
    Florida
    45
    Done.........and again thanks for all the responses.
