Measure your actual pool water depth to get a better read on your volume in PoolMath: Pool School - PoolMath
That link will also help you with desired levels.
To siphon, you can use multiple hoses. If you have a large vacuum hose, that helps a ton. Also, if those aren't options, big box stores rent submersible pumps.
As for the link you posted, vinyl, with bleach. However, PoolMath will zero in the levels you need, except for the slam. We can talk about that after you drain and refill.
