Sorry, just saw that you had posted. I'm on vacation so I forget to check sometimes. I use a small funnel and a piece of garden hose. Mine is set up in a manifold fashion, so I disconnect the manifold by unscrewing one side of my valves. Then I stick the hose down each line and pour a gallon or so in each. Then put it all back together. On the main drain, I pour in a gallon or so and just let the vacuum push for about 30 seconds then valve it out. My shop vac isn't powerful enough to blow the main drain so I figure a slug of rv antifreeze with an air bubble on top should do the trick. Never see any pink coming out the main drain when I do it, but I think it's close.
