Sun and algae both consume your chlorine and it must be replenished when that happens. Right now you have a LOT of algae so it will consume a LOT of chlorine. You have to add bleach and test often. You can't just dump it in and walk away, you will need to test often and maintain your level. This may require testing hourly at first, test the water and add chlorine to keep your FC level at 12. As the algae is killed off and the pool begins to clear you will be adding less and less bleach, and your FC level will maintain longer and longer. Letting the FC level drop for any length of time allows the algae to start regenerating again and algae grows VERY fast.
It is very important you get the FC up and keep it there. The more often it falls below SLAM level the longer this will take. You need to be stocked up on your bleach supply so you don't run out. Make sure you are testing using the 10ml sample size, this will save on reagents so you don't run low in the middle of this. Once the pool is clean you won't use much bleach at all. Not sure of your pool size but my 14k gallon uses about 32-40 oz per day to maintain the beautiful clear water.
I know you want to close it up and be done but you will have to go through this at some point and the cooler fall temps will make it much easier. Remember to keep brushing the walls and floor and use a leaf net to scoop out as much solid material as you can. Keep your filter running and backwash or clean as needed to filter out the dead algae.
