Your CYA could be anything, then. (The cost of the test kit is offset by the savings in chemicals, by far.) not flaming at all, just speaking the truth.
Believe it or not I don't work for Taylor or TFP. I genuinely like help people take control of their pools, understand and maintain them and ENJOY them. I like to help so much that I took the time to read through all 50 something of your posts here and noticed that you have never posted "real" results and wanted to confirm.
It's your hole in the ground filled with water to take care however your would like. And you'll get no flaming from me. But step 1 of TFP is a test kit that accurately tests the water. Proceed as you wish
If you've looked around much, you will see we don't take much stock in Leslir's testing, either. They either use strips, or indoors with bad lighting.
Do they go outside to do the CYA test? There's a marked difference between doing it indoors and out. I've seen people report a difference of 20-30 between lighting conditions. But, alas, it's your pool and your.money .good luck.My Leslie's uses a Taylor kit
Right now I'm out of liquid bleach because of all the black algae and SWG not working because the flow wasn't fast enough. I have to check every day in diagnostics to make sure it shows ok. I'll try to clean the filter today and hopefully that helps with the foam. I'm trying for 80 on CYA. I've gotten it down to about 120 now. I have tons of shock packs but they contain stabilizer so I quit using them. Need to run to Walmart and pickup some pool bleach.
Since you noted I've never provided results I decided to run both the AquaCheck and the InstaLink that I don't like. Here you go.
AquaLink InstaLink
Alk 120 210
Ph 7.2 8.4
TC 3 n/a
FC 3 7.5
Hrd 500 450
Cya 50 150
I hope this helps. I quit using the InstaLink when the results swung wildly from test to test all done within a few mins. The AquaLink matches closely to what I get using my 5-way chemical test kit. I just can't check the cya without using these two tests.
Ok, so I can only hang with you if I buy a kit that is recommended on this forum but not used by everyone?Then, when you are interested in maintaining your pool with minimal effort (and money!) get a good test kit and come back and hang with us.
This afternoon you say your CYA is 120ppm .......
Tonight you say the AquaLink is what you prefer to use, and it shows a CYA of 50ppm
Thats a pretty big difference.
As I said earlier I'm out of liquid chlorine and will be purchasing more ASAP.
Of course not. You can hang anytime you want, but I'm not sure how much fun you are going to have when every interaction seems to upset you. I can assure you that no one has any intention of anything other than helping.
