I will take this one test at a time if needed:
-FC-it might be stronger than you think OR your pool size needs to be tweaked. No big deal. We will work on that.
-TA-you pushing the PH down as the plaster cures should help lower this one.
-CYA-Oh how I hate this test LOL-when you do this test do NOT stare or LOOK for the dot. GLANCE only. GLANCE in the tube and look away.If you stare you will end up seeing that dot as you have seen. You can do and redo this test to find the level. Just pour it back into the bottle and do it again. Pour to each line, GLANCE in. If you see the dot pour to the next line. Continue this until you cannot see the dot with a GLANCE.
TDS=Pool $tore's way of making more money off of you. It is of NO importance to you or your pool.
Have you tested your fill water yet? I have my fill water test results on the cover of my test results note book. It helps me remember what I have to tweak when I add water from the hose.
Kim
Kim
