Holydoc
- Jul 17, 2016
- 499
- Plaster
- Hayward Aqua Rite (T-15)
When I did my CYA test of the known 50, I did the following:
With that said, I am in total agreement with everyone here. This test should NOT be that hard. I mean what are the chances that I will get exactly the same light every time I test? So what I learned today is that if the light is a little bit different, it could cause your testing to be off as much as 20ppm. That is huge!
I currently test once a week for CYA. What I am going to do is test the Known 50 first each time to ensure I have a good light, and then test my water. This will hopefully keep me from messing up too bad.
- Taylor K-2006 tester
- Outside at 10am in the morning
- Clear bright day with sun at my back
- Test container on bar approximately waist height. (I did not hold the test container)
- Back to the sun with shadow of body on test container.
- Added solution until I could move my head from side to side and not make out black dot.
- Test showed 50.
