I have had nothing but issues with the install of this pool. First it was many leaks, I got those handled. Now I am having issues with the filter/pump assembly setup. The pool still plagues me. So last night I ran the electric for the pump. I hooked all hoses up to the pump, filter/frog system, skimmer, and return according the instructions. it said to open the air relief valve on top of the filter, i did that. It said to turn the pump on low and allow the air to purge from the system and once it started spraying water out of the air relief to close it. I did that too. The problem is water is still coming out of the air relief, and there is water coming from the band clamp that holds the two filter halves together. The pressure gauge reads 0. I am just not having good luck with this pool. This pump/filter was bought new so this is the first time its been used. Do I need to replace gaskets/o-rings? I am at a loss. Its a new system and I am having nothing but issues. I cant help but feel that I am screwing things up and I am more than ready to just toss in the towel. The filter is a Backyard Auqa Design D.E. filter system which is a Waterway system.
