BlondeeSue66 said:The ph is at 7.2 after acid, the cl is still at 5 do I still add bleach even though it stayed stable? do I always add bleach each day or just when needed?
Thanks
You add enough bleach each day to keep your FC at the recommended levels according to the CYA chart. For your CYA of 30, your minimum level is 2, you "target" 4, and you shock to 12. Since you can only test to 5, and can't easily test for CC, we are just using 5 for now, since that's all you can do with the OTO.
When you get the good kit, you can test FC with the FAS-DPD more precisely and then we can determine if you need to shock, or let the FC remain at normal levels.
So each nite, you test your FC. Say for example its 2. You add enough bleach to raise the FC to 4. You will repeat the testing/bleach addition the next nite. Say the next nite the FC is 3, you don't have to add as much bleach to reach 4. I hope that makes sense. You will test each nite until you get to know your pool, then you might be able to swing every other night.
You're doing great.
