Something isn't set correctly in PoolMath. Recommended TA should be 60-80.
Pool School - Water Balance for SWGs
Plaster | with Bleach FC 3-7 (See chart) pH 7.5-7.8 TA 70-90+ CH 250-350 CYA 30-50 |
Pool builder is adding salt tomorrow! Anything I need to prepare for/expect?
Give it 24-48 hours to fully dissolve and mix into the water.
You should run the tests and add (or not) as the tests and Pool Math tells you to. Trust your testing and let it guide your additions.
Do you have a SWG?
Yes I do. I assume I have to run the pump continuously for 2 days to get a full mix? MY CYA is at 40 so I asked them to add stabilizer to get it to 70.
