Wife got this pool for us and the grans. Found this site through a member on a total different website. Using 320 lbs of salt and my SWG to start, got the ph ok with 3 lbs of borax, easy. Now the ? have run the SWG maybe 24 hrs, the TFTest kit shows no chlorine with the 2 provided test, the CYA test is zero, black dot clear as a bell with tube full. Help an old guy out with what to add to start this going in the right direction. Pool was filled with county tap water about 6 days ago. THANKS (Wife has threated taking sample to pool store) Water appears clear to my eye, can see bottom of pool very good.
