Looking for any ideas. I have gone through 4 JandyColors Digital Blending Lights in 3 years. I have two of these lights, one in the spa and one in the pool. They are both the pool sized lamps. I have had no problem with the lamp in the spa, works flawlessly. The light in the pool seems to burn out bulbs for some reason. There are 8 bulbs per light, and I inevitably notice that the colors don't look right. I then put it into Color Splash Mode to determine which bulb is out. I have been replacing the lights under warranty, but the warranty is now expired. Obviously there is a problem. The lights are connected to a Jandy AquaLink RS. Each time I had the light replaced I asked the installer their opinion. They all said bad luck. Obviously something more than bad luck is burning out these lights. What should I do? I will attempt a bulb replacement myself even though most people just buy a whole new light. It has got to be an electrical problem, right?
Thanks in advance for any ideas.
