- Jan 4, 2016
- 5,289
- Plaster
The TF 50 is designed as a complement kit for someone who already has and wants to use a 4in1 style kit. So the answer is yes as far as minimum requirements.
You also get fewer tests of:
Test | TF50 | TF100
CYA | 3 tests | 16 tests
FC | 35 tests | 70 tests
The TF50 does not include OTO chlorine, which some people use a quick daily checker for FC
If it were me, I'd get the TF100 because of the better long term value. You can see how the two kits compare and use up the reagents in the Pentair kit if you're happy with the reading. The reagents keep well as long as you keep the kit out of the weather for storage. If you can swing the extra $35, people swear by their speed-stirrers. At one time you got free shipping if it was over $100, so that might be a consideration.
Also, check out "Become a supporter" linked in my signature. It's a modest one-time donation, tax-deductible, and I think gets you a coupon at TFTestKits. All the advice is volunteer here at TFP, but the little donations cover the forum costs and keep everything flowing.
Here's the table which is accurate for the TF test kits: Pool School - Test Kits Compared
Hi, my vote is to go ahead and get the TF-100, it only cost a little more and is the better value by far. As to the rest, how can someone be against bleach and for liquid chlorine, they are the exact same thing, just liquid chlorine tends to be stronger (Bleach typically runs 5.25-8.25% Sodium Hypochlorite, and Liquid Chlorine is typically 10-12.5% Sodium Hypochorite, although sometimes as low as 8.25%, the remainder is basically salt water) In other words the weaker Liquid Chlorine you can sometimes find for sale is the EXACT same stuff as the stronger Concentrated bleach, the only difference is the label. For pump run times, yours sounds like it is probably excessive, but not too bad see Pool School - Determine Pump Run Time
Personally, I don't think the K-2006 is good value. It has around 25 FAS-DPD tests, which you would use up in a month getting accustomed to everything. You will slow down on testing after a little while, but initially people test a lot.
Glad to hear that you got someone good to explain stuff . The pucks will help bring the pH down, but 8.2 is high (and could be higher when the test indicates its upper limit) so I'm surprised he wouldn't correct that. Also, I would add liquid chlorine right away if I saw zero chlorine, albeit carefully with new plaster.
Pumping sounds excessive to me, but it's very pool specific. There's a procedure that helps people work through it, linked below. The current schedule certainly won't hurt anything. It's just electricity to pay for. If it was mine, the 12 hours is fine, but I would run lower RPM and I don't know why you would need a higher flow rate with a robot. My pump runs at high speed for 3 minutes to be sure of prime and get the water moving, then 1600 RPM the rest of the time. I have a suction cleaner I use once or twice a week and it likes 2600 RPM. Pool School - Determine Pump Run Time
I don't mean to bag out the pool school guy at all. We kinda go for optimums here, and I didn't hear anything that would hurt your pool. I would keep the FC commensurate with CYA, and if CYA is zero, I'd do all I can to keep it between 1 and 2 ppm FC with pH 7.5 to 7.8
Get that test kit ordered!
Very nice! Does it run off a sensor or a timer?
Drinking and brushing don't mix.QUOTE]
LOL!
Acid dispenser... Dang, I'd love to have one of those right now.
Great looking pool!
Pump run time sounds good but I agree the speeds are a little more than you need for circulation. A higher speed for the cleaner, SWG (when it is hooked up) and skimming may be necessary but for the majority of run time a slower speed that keeps the SWG happy is more than enough.
With all the folks from Texas maybe we should change the forum name to TTFP?
